removed my air silncer at 1am
Old 08-20-2003, 10:13 PM
Buzzstang
Buzzstang's Avatar
Default removed my air silncer at 1am
did you know a new ford filter will flow more air than a k&n filter? of coarse you can wash a k&n filter.
Buzzstang is offline
Old 08-20-2003, 10:18 PM
allblack
allblack's Avatar
really? so which do you recomend
allblack is offline
Old 08-20-2003, 11:36 PM
Buzzstang
Buzzstang's Avatar
in the long run the k&n will be cheaper and you dont loose that much air from it. after you run the ford filter a while it will clog up a restrict the air flow. the k&n will still be going strong. i had on in my 94 until it got the CAI
Old 08-21-2003, 12:35 AM
Redline5th
Redline5th's Avatar
Well I didn't know that the ford one was better...go with the K&n like you said the other will clog....
Redline5th is offline
Old 08-21-2003, 12:58 AM
vfast
I ♥ Acer
vfast's Avatar
buzz..are you stealing my information again?*L*
it will for about 300 miles
vfast is offline
Old 08-21-2003, 10:10 PM
Buzzstang
Buzzstang's Avatar
no just passing on information!<IMG src=smileys/smiley4.gif border="0">from on stanger to another.
Old 08-21-2003, 10:24 PM
allblack
allblack's Avatar
hey guys do you think it is worth buying an expensive cold ait kit or is it going to be any better than if i put a kanN in my stock intake with the silencer removed?
allblack is offline
Old 08-22-2003, 12:42 AM
vfast
I ♥ Acer
vfast's Avatar
all black make you own for about 25 buck..those tin and alum hold heat..do you see one on a stock car?..I run a moroso it's polymer plastic..got it on e-bay for 20.00 bucks with fiter. you can make you a nice clean upper for about 8 bucks that will out flow the mac and others<edited><editID>vfast</editID><editDate>37854.9466435185</editDate></edited>
vfast is offline
Old 08-22-2003, 12:50 AM
allblack
allblack's Avatar
ok...so if i do buy a cai it should be made of plastics
allblack is offline
Old 08-22-2003, 01:22 AM
jeep45238
I ♥ Acer
jeep45238's Avatar
Doesn't really matter.
With metal, although it may be hotter to the touch, air is moving so fast through that tube it doesn't have time to pick up any noticeable heat (4F MAX is what I have seen in most cases).
Go with what ever's cheaper......and that would be exhaust pipe, rubber elbows, adapter or two, and a filter from Autozone.
jeep45238 is offline
Quick Reply: removed my air silncer at 1am
