afr 165 or trick flow twisted wedge?
Old 05-02-2007, 01:34 AM
  #21
LTnone
LTnone's Avatar
Default RE: afr 165 or trick flow twisted wedge?
[Awaiting Approval]
See? I can do it too
Seriously though...people on this site can be ridiculous sometimes. Everyone is so quick to hop on the AFR bandwagon that they ignore a little detail every single time- TW's and 165's are pretty much equal, and if anything the wedges outflow the 165s. People can't seem to get this through their heads, no matter how many threads we have discussing it... Now compare both of those after porting, and the AFRs get blown out of the water. Not to mention that the TFs are still a good bit cheaper.
Table 1: Intake Flow (CFM 28" H20) lift (in.) TFS* AFR .100 62 60 .200 131 125 .300 193 188 1.400 230 226 .500 242 238 .600 242 248 Avg. 199 194.3
Exhaust Flow (CFM 28" H20) lift (in.) AFR TFS .100 52 48 .200 100 97 .300 142 134 .400 168 161 .500 181 178 .600 189 189 Avg. 148.7 142.5
LTnone is offline
Old 05-02-2007, 01:45 AM
  #22
85GTsleeper
85GTsleeper's Avatar
if you dont want to get into the whole porting argument then i would say afr's
85GTsleeper is offline
Old 05-02-2007, 02:12 AM
  #23
94StinkinLincoln
94StinkinLincoln's Avatar
what about edelbrock performer RPM heads with 2.02 intake valves?
94StinkinLincoln is offline
Old 05-02-2007, 02:21 AM
  #24
OnyxCobra
OnyxCobra's Avatar
In one of the Head chart comparrisons i have it shows the AFRs outflowing the Trickflows by a lot on the exhaust side, which is why i'm guessing the AFRs usually make more power than the TFTW even though the intake numbers are very similar. My dad has a set of TFTW heads and I have AFR 165s, we put them side by side and after looking at the ports its pretty easy to see why the AFRs cost more. From what ive seen online the AFRs usually make more power than the Trickflows regardless of what the charts say.
OnyxCobra is offline
Old 05-02-2007, 02:43 AM
  #25
tokinGLX
duke of herb
tokinGLX's Avatar
also keep in mind that between the twisted wedge and 165s, the tw have bigger intake valves. 2.02 vs 1.9
i bought my 165s because the tech dude i was talking to at afr recommended it over its higher flow bretheren.
link for you nooblets out there(damn, i feel sorry for you folk running stock heads)
tokinGLX is offline
Old 05-02-2007, 12:03 PM
  #26
dthompson67
dthompson67's Avatar
which is better with no porting done to them? if any to get them to match gasket or the victor jr intake?
dthompson67 is offline
Old 05-02-2007, 12:21 PM
  #27
ooticamitica
ooticamitica's Avatar
afr's are better but the tf kit is good, of course you can make better by mix matching good parts w/ a custom cam.
ooticamitica is offline
Old 05-02-2007, 12:25 PM
  #28
dthompson67
ok tell me which would be better and whats the hp estimates
holley 650 doubple pumper
victor jr intake
trick flow heads (not ported) or would i need to do somet port work to get the to run right?
.512 custom ground cam (do i need a bigger one)
.40 over flatop stock style pistons
let me know and then how would it be if the heads were afrs?
Old 05-02-2007, 12:33 PM
  #29
92GreyGT
92GreyGT's Avatar
I like them both but DSS told me to go with AFRs. With your set up I would either get the CNC ported Trick Flows or the 185 AFRs. They will be close in price and are both excellent choices. Be careful with the stock style pistons and 2.02 valves. A custom cam would be better that way it can be ground with the proper timing needed to clear.
92GreyGT is offline
Old 05-02-2007, 12:50 PM
  #30
dthompson67
ok what would be some good pistons. cam and heads that will all match good and be fairly under 1300 or so. forged aluminum pistons and stuff? let me know what would be good and the hp estimate
Quick Reply: afr 165 or trick flow twisted wedge?
