late spark
late spark
Hi, Ive been trying to converts a 4 to an 8 for a little while now and am getting very close. THe wiring is really messing with me. Ive got a 347 with an 89 engine harness that goes back to a 88 8 cyl computer. Ive also put an 89 harness in behind the dash that goes to igniton and out the firewall on driver side. This is all in a 93 lx. Its got new comp, new igntion module, ignition switch. Ive got everything pretty much working now but when I turn it over there is no spark until I let off the key. Ill turn it over and have no spark but the second I let off the key there is a quick spark. If anyone can help me I'd apreciate it a lot</P>
thank you
Jamie </P>
late spark
Well on the computer I bought it said it was mass air and it is the same number computer as what I had (A9L) I believe it was. We just figured out though that when the key is on and we jump the starter solonoid, (screwdriver across the two points) it has plenty of spark, so we did this just to see if it would start and now we found out its not getting fuel, the rails are pressurized but its not going through the injectors. I put on 30lb injectors and have an accufab adj press reg. We tested the voltage going to the injector to see if it was getting enough juice to open the injector when it needed to be but it was only getting something like .18 volts. does anyone know what they shud be getting and if not that then what to fix?
late spark
how did you test this ? you dont at least that i know of. a voltmeter while connected to the positive side of the injector is not fast enought to capture that . only noid light and labscope will see it. if your getting spark the pcm sees the pip signal and know the motor is turning over . is your maf calib for those injrctors . your injector harness connection ok?
late spark
Yes I did test with voltmeter, didnt realize it wasnt quick enough to capture the reading. Well I have a new mass air flow sensor that was supposed to be calibrated to the injectors I have. Its a 76mm mass air flow. Injector harness is connected securely. Think I could have been lied to about the computer being a mass air flow computer? They told me it was out of an 88.
