Look what boost did for me :(
Old 05-18-2007, 07:32 AM
94IVGT
94IVGT's Avatar
Default RE: Look what boost did for me :(
ORIGINAL: kev2369
ORIGINAL: 67mustang302
Looks to me like your ring end gap might have been too tight, butted and the ring bound in the land against the cylinder wall, and snapped the top off that part of the piston. That's why you need more ring end gap for blown/nitrous Is the cylinder wall scratched on that side?
Be honest with ya, i'm not sure on the scratch on the wall... I didn't put the bottom end together, and its been together for a while... It ran with ten pounds of boost for about 5k or so and never had any problems... But i had a set of heads and some parts laying around so i decided to bolt them on my car, and only had problems after they went on... For some reason it keeps ruining head gaskets between the cylinder wall and the water jackets... All i done when i pulled the heads off it saw the busted piston then flipped it over to see how the bottom end looks, which was fine, then i've been on vacation since
i have been having the same problem with the headgaskets blowing between the cylinders and the waterjackets. cant figure it out vortech s/c kit on the car as well. timing at 10degreesbtd. any ideas on this???
94IVGT is offline
Old 05-18-2007, 11:47 AM
ruger311
ruger311's Avatar
that sucks dude
ruger311 is offline
Old 05-18-2007, 12:24 PM
samseed101
samseed101's Avatar
I would never keep the timing at 10 degrees with a supercharger unless I had methanol spraying in there. Colder plugs and a degree or two back... that's what I did.
samseed101 is offline
Old 05-18-2007, 05:24 PM
luckythirteen13
luckythirteen13's Avatar
running stock timing is what killed you. with 8psi of boost you should have pulled around 8* total timing depending on the rest of your mods
luckythirteen13 is offline
Old 05-18-2007, 07:22 PM
aode08
aode08's Avatar
after you replace that piston, get a thick headgasket to lower the compression some.
Set the timing to 6-8 degrees with spout unplugged. You dont want combustion 10 , 13 14 degrees btdc before the piston is at top dead center with a stock setup, no no no.
Also be sure to use that $4.00 per gallon premium 93 and up not 89 or 88[&:], I wouldnt worry, this is a learning experience, gotta pay to play[:-]
aode08 is offline
Old 05-18-2007, 07:39 PM
67mustang302
67mustang302's Avatar
Using a thicker gasketmay bea bad idea. It will lower compression, yes, but by very little, and it will have the negative effect of increasing quench height which may increase the possibility of detonation. You need to make sure your quench height is right for the gasket and deck clearance you have
67mustang302 is offline
Old 05-18-2007, 08:07 PM
stang8689
stang8689's Avatar
your car still looks and sounds sick so get the MF back together, might as well do a 331 stroker now
stang8689 is offline
Old 05-18-2007, 08:51 PM
my77stang
my77stang's Avatar
my essssplosion still reigns supreme
my77stang is offline
Old 05-18-2007, 09:45 PM
Speedy911
Speedy911's Avatar
It seems like 95% of engine faliures are someone's mistake at some point in time, either the builder or the operator
Well it isn't going to be the cars fault :P
Speedy911 is offline
Old 05-18-2007, 10:16 PM
2 kwik
I ♥ Acer
2 kwik's Avatar
you know it's kinda funny non of you guys with nos or an S/C index your plugs[&:]
2 kwik is offline
Quick Reply: Look what boost did for me :(
