Replacing the Clutch Pedal Assembly
#21
RE: Replacing the Clutch Pedal Assembly
ORIGINAL: 945LSTANG
i have no idea y the bar is there. ive never seen that before
I figure I will just rip it off if I can, but it's welded on and it's attached to a bold on near the driver door which is almost impossible to get to.
#22
Ok next question:
How do I get a 20 year old bolt to budge (this is for the seat)? I have sprayed it with WD-40 and that hasn't helped. I only have a rachet, I need to get a 15mm wrench from my bro, but not sure if the wrench will be any better.
#24
ORIGINAL: 94gtcoupe
don't waist time with WD-40 PB blaster works TONS better
I got a breaker bar from my brother this morning and some other stuff to spray on the bolt. Now I know why he complains about working on cars and doesn't want to help me - :P
Thanks for the help.
#25
T, I am planning on working on the stang tomorrow to fix my vibe issue, and I'll snap some under the dash pics if they'll help you. I'm not sure what that bar is, off-hand, unless it is one of the braces that connects the assembly to the dash/frame.
#28
ORIGINAL: gspfunk
It is attached to the dash/frame near the driver door uner the dash.
It could be a brace because the person drove it to hard. I am starting to think this person raced it a lot, and now I am fixing what he broke.
#29
ORIGINAL: mattdel
those bars look like he fabbed up some structural support for the whole assembly.
maybe **** was breakin on him from hittin the pedals too hard.
#30
ORIGINAL: 945LSTANG
id use an impact wrench on that bolt. the breaker bar might work.
Would it be wise to take out the steering column as well?
