STARTING PROBLEMS PLEASE HELP!!! VERY IMPORTANT!!!!
RE: STARTING PROBLEMS PLEASE HELP!!!
ORIGINAL: AdderMk2
check for voltage at the inertia switch.... they go bad
fuel pump relay is in the CCRM... good luck with that
the big black box thats kicking your ***....
its attached to the coolant overflow bottle and has a big wire harness going into it.
I still suggect checking voltage at the inertia switch first
hahaha nice way of putting it....
well that helps we can try that tomorrow....if skinny will get on he can tell you more about what all we checked
Fuel pump better not be dead we just bought that....
skinny just said that he tripped the inertia switch and got nothing and he wants to know why he cant read the computer with his code scanner.....when he plugged it up with the key off the little red light came on on the scanner.As soon as i turned the key on, the light went off and he got nothin.
