One step closer to solving the Procharger problem...
#21
RE: One step closer to solving the Procharger problem...
ORIGINAL: samseed101
No kidding. I don't know why they set it up that way. It basically sucks in hotter air and takes up more space in an already cramped engine bay. I got the idea of which filer to use from kev2369 and then I expanded on the idea to box it in and give it some cooler air from the the fenderwell. But the weekend is over and it's back to work tomorrow so it looks like I won't be making anything this week.
#23
ORIGINAL: kev2369
Glad to see that you found that filter... I haven't had any trouble out of mine, plus it is rechargable so it fits the trick... I thought about an isolation box for one but i never could really see where there would be room for one, so i just smiled cuz i only had 15 bucks in my solution... Good luck
True, there's not much room there, but Im sure i can fabricate something. Especially since I'm gonna cut a hole into the fenderwell.
#24
set it to 1.250 idle and 2.8 wot breakpoint, youll love that setting alot better , and performance will increase substancially.
thats where you belong
#25
Yup, found it right where you said it would be. Picked it up today.
ORIGINAL: kev2369
BTW, my fenderwell is cut out and i still don't see how it will ever fit...Good luck though
#26
I'm not gonig to get the actual filter into the fenderwell (well I may if I can find a way to do it with one of the parts in the link provided by Bernie.) I plan on curring it out and then "boxing" off the filter in it's current location so that it's isolated from teh rest of the engine bay and instead, pulls it's air through the fenderwell.
#28
ORIGINAL: VigCS
Does it really matter where the filter is? I ask becuase your system is intercooled, right?
#29
To look at it another way... think of an intercooler trying to cool down air that is 120 degrees as opposed to an intercooler that's trying to cool down air that's 80 degrees. In either situation it will cool down the air temperature... but you will get better results with the cooler air.
#30
how did those mods turn out, the settings and exhaust wrap etc?
if you dont wanna wrap, there are universal foil shields that does the same thing
