Convertable top Adjustments
Does anyone know how to adjust the top so it sits on the seals better? i had a new top put on along with a set of new window seals, and it dosnt really sit on the seal great theres gaps all over the place any help would be greatly apreciated.
RE: Convertable top Adjustments
the seals are Brand new and where just installed, the hooks seem to fine, i dont see how that would adjust the hight but Urgh, is there a adjust me on the windows to make them go up farther?
if your really that far off, you better go over your work again. something isn't right.
when you put the top up, it should fall right onto the windows, then the windshield latches secure it all the way around.
every thing was installed at the same time, not sure whats going on, it has always had the gaps thought the seals where bad, well i know they where bad but i replaced them hopin it would fix the gapin problem, everything was installed by a Shop that does this kinda work and just getin fustrated with lookin at the gap problem,
It may help solve your problem or it may not.... but either way I highly recommend this manual. You'd be suprised at how many different adjustment possibilities and procedures there are in this book and the procedures are very well written
http://www.mustangsunlimited.com/ite...p;CatKey=74-01
LivingInThePast
09-16-2015 12:20 PM
