What more for suspension?
#21
RE: What more for suspension?
oh i got them from UMI, i would've loved to make them myself by i didn't have the luxury of having someone give me the measurments... the install took 4 hours including the control arm, but about 2 of those hours was trying to get the freakin' control arm bolts out and getting the material under the seat off to have a welding area.[:@] ...i have to do the other side today, hopefully it'll go smoother.
#23
ORIGINAL: 7upedition
+1000 on torque plates, wolfracecraft has then for $30... fit well
Roll cage will stiffen you up a lot too, even if it is only a 6 point, hell you got a good welder too.Also loode the weight... remove all extra stuff, battery relocate to rear pass side, underdrive pulleys, electric fan, smog pump delete, etc... i know its not all suspension, but it all helps with the main goal.
What do you have for a transmission?
#25
ORIGINAL: 90mustang5.8
i might go tubular k member.....but i dont know for sure, sorry this is when my retardation kicks intorque boxes are what exactly? and im really good at mig welding if that helps me any.
and really u dont need to do much else to there rear... mayb a nice URP k-memeber kit... comes with k member a arms and coil overs for hte front.... then some stick raidals.... and thats about all u can do unless u upgrade somethin u already have done
#27
talked to a guy at the track tonight with a 93 5.0.....he said to do welded boxes and air bags....5lbs driver side and 12lbs passenger side, so i guess i'll do that also. i prob wont have some of this done when my car is finally running becasue i just want to get it a pass before the season ends...then i can do a whole lotta work over winter
Matt's 95 Stang
10-05-2015 07:16 AM
