What more for suspension?
Old 06-14-2007, 11:27 PM
90mustang5.8
I ♥ Acer
90mustang5.8's Avatar
Default What more for suspension?
What else couldI add for drag suspension on my car? Heres whatI have so far: Lakewood 90/10 and 50/50 struts, sub-frames, no front sway bar, UPR upper and lower adj. control arm(have notbought yet), 4 cylinder springs, centerline drag aluminum wheels, and M/T drag radial tires.I dont know too much about suspension butI know a little, for some stuff you might have to do some explaning.
90mustang5.8 is offline
Old 06-14-2007, 11:47 PM
notch5oh
notch5oh's Avatar
Default RE: What more for suspension?
torque box reinforcments would be a good choice
notch5oh is offline
Old 06-14-2007, 11:54 PM
94StinkinLincoln
94StinkinLincoln's Avatar
how hard would it be to make the tq boxes? my dad is a welder/fabricator by trade.
94StinkinLincoln is offline
Old 06-15-2007, 12:29 AM
20yrNotch
20yrNotch's Avatar
you can probably find a good pair on summit and have your old man weld em on
20yrNotch is offline
Old 06-15-2007, 12:34 AM
w8less
w8less's Avatar
zmotorsports.net
wolferacecraft.com
for the torque boxes definitely something to think about.
tubular k-member kit
w8less is offline
Old 06-15-2007, 12:44 AM
90mustang5.8
I ♥ Acer
i might go tubular k member.....but i dont know for sure, sorry this is when my retardation kicks intorque boxes are what exactly? and im really good at mig welding if that helps me any.
Old 06-15-2007, 01:04 AM
90mustang5.8
I ♥ Acer
^bump
also anything else i should add
Old 06-15-2007, 01:59 AM
justakid
justakid's Avatar
-Rear: LMM Platinum Springs with Poly Isolators and 50/50 Lakewoods -Front: 140lb D&D Coilovers with 90/10 Lakewoods -4 Cylinder Springs -Upper and Lower Control Arms -BBK Subframe Connectors
no more, no less
justakid is offline
Old 06-15-2007, 03:31 AM
90mustang5.8
I ♥ Acer
ic
Old 06-15-2007, 03:54 AM
HC_CrAzYHoRsE
Super Moderator
HC_CrAzYHoRsE's Avatar
ORIGINAL: 94StinkinLincoln
pretty easy actually, i just installed the passenger side today along with the control arm... i'll take pics and measurements before putting the driver's side in tomorrow.
HC_CrAzYHoRsE is offline
Quick Reply: What more for suspension?
