which MAF?
Old 06-15-2007, 09:08 PM
steel1
steel1's Avatar
Default which MAF?
Looking to upgrade my stock maf sensoron my 93GT. Does anyone know which brands are good/reliable. Must work with 19# injectors, E-bay has a bunch, but they seem to have alot of cobra knock-offs. The only other brand I see alot of is C&L. Any suggestions?
steel1 is offline
Old 06-15-2007, 09:42 PM
samseed101
samseed101's Avatar
Default RE: which MAF?
This is an easy one. Buy a 70mm MAF from a 1994-1995 Mustang. They're dirt cheap and very accurate.
samseed101 is offline
Old 06-15-2007, 10:27 PM
luckythirteen13
luckythirteen13's Avatar
pmas ftw!
luckythirteen13 is offline
Old 06-15-2007, 11:16 PM
5.0stanger
5.0stanger's Avatar
ORIGINAL: samseed101
Why where you ragging on me for doing that??
I would also recommend one, but you will need air filter/air box adapter also.
5.0stanger is offline
Old 06-15-2007, 11:57 PM
steel1
steel1's Avatar
Does the adapter take it from a square4bolt pattern, to a 3inch round opening, so I can mount my cone air filter??
steel1 is offline
Old 06-16-2007, 12:00 AM
samseed101
samseed101's Avatar
ORIGINAL: 5.0stanger
I was bored I actually ram my SN95 MAf for awhile even after i got my s/c. But I eventually had to dump it. My supercharger was pegging the meter at about 4000 RPM and that was way too early to max it out. Plus I needed a blow through MAF anyway.
Old 06-16-2007, 12:08 AM
Glasersil
Glasersil's Avatar
SCT2400 and be done with it!
Glasersil is offline
Old 06-18-2007, 04:56 PM
jasonvri
I ♥ Acer
jasonvri's Avatar
ORIGINAL: Glasersil
Holy Overkill Batman!
Not a bad choice though, they are supposed to be very good meters...\
If something that big is needed then I would go with a 90mm LMAF.
The only reason I would use SCT MAF is if I was pegging out the 90 LMAF. The SCT's are kinda pricey for my taste...
jason
jasonvri is offline
Old 06-18-2007, 05:18 PM
5.0stanger
5.0stanger's Avatar
ORIGINAL: steel1
Yes, that is how I made mine.
Jb145700
08-21-2022 06:37 AM
jwog666
12-27-2021 08:09 PM
piotrek53
10-13-2015 06:54 PM
mltdwn12
09-23-2015 08:54 AM
stangin1996gt
09-21-2015 11:01 AM
Quick Reply: which MAF?
