Thermactor Air System, Code 94 Help
Old 06-15-2007, 10:39 PM
Hawk
Hawk's Avatar
Default Thermactor Air System, Code 94 Help
Just wondering if someone could help me understand the thermactor air system on my 88 GT. I have a code 94 and imagine that the AIR system adn Thermactor Air System are the same thing. If anyone could shed some light on how to fix this problem, or to understand how this system works in the first place it would be appreciated.
Hawk is offline
Old 06-15-2007, 10:42 PM
93 LX FiveO
93 LX FiveO's Avatar
Default RE: Thermacitor Air System, Code 94 Help
goodluck
93 LX FiveO is offline
Old 06-15-2007, 10:45 PM
Hawk
Hawk's Avatar
LOL, I know. You have to love smog related crap under the hood. Unfortunately if I just remove everything I don't think I will get through an inspection. So for now, its all about trying to fix things.
Hawk is offline
Old 06-15-2007, 10:46 PM
93 LX FiveO
ive had the same code for 6 months now. 94 and 44
my smog works perfect (when cats are on it)
passed MA sniff test with flying colors
i wouldnt worry about it
Old 06-15-2007, 11:01 PM
Joel5.0
Joel5.0's Avatar
94 - Secondary Air Injection Inoperative. bank two, driver side (R).
Usually caused by a clogged crossover-banjo tube to the back of the cylinder heads, and/or clogged passages at the cyl. heads....a faulty TAB or TAD solenoid....would cause both codes (44/94) to show up.
Joel5.0 is offline
Old 06-18-2007, 10:17 AM
Hawk
Hawk's Avatar
Joel
Thanks for the reply. I will definitely have to check that out. You wouldn't happen to have a picture of the Crossover-Banjo tube so that I check the correct thing?
Hawk is offline
Old 06-18-2007, 11:22 AM
Joel5.0
Joel5.0's Avatar
Sure.......here you go....tagged with #4 below.....
Joel5.0 is offline
Old 06-18-2007, 11:56 AM
Hawk
Hawk's Avatar
Thanks man! Is this something that once removed could get cleaned with some carb cleaner to solve my issue?
Hawk is offline
Old 06-18-2007, 04:27 PM
Twisted
Twisted's Avatar
You'll probably have to snake the crossover pipe with a coathanger or something. Mine was pretty clogged, and I had to mess with it for like 30 mins before it came clean.
Twisted is offline
Old 06-18-2007, 04:41 PM
Hawk
Hawk's Avatar
Coat hanger it is, thanks man.
Hawk is offline
Quick Reply: Thermactor Air System, Code 94 Help
