wheel spin around a corner and from.....
Old 06-16-2007, 09:40 AM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Default RE: wheel spin around a corner and from.....
All I can tell ya is how mine works. new trac-loc w/ carbon fiber clutches and when I hit it on a turn the entire rear will slide. maybe you guys aren't making enough power for this to happen.(and I'm not trying to be a dick either by saying that)
PRO50SC is offline
Old 06-16-2007, 09:44 AM
tmajikman
tmajikman's Avatar
It is strange, I actually remember taking a left and the back end did let loose on both tires, can only one side of the trac loc wear out quicker than the other (the clutches). How difficult is it to replace the trac loc clutches.
tmajikman is offline
Old 06-16-2007, 10:12 AM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Repalcing the clutches is not that hard at all.
http://www.mustang50magazine.com/tec...ild/index.html
PRO50SC is offline
Old 06-16-2007, 10:25 AM
tmajikman
tmajikman's Avatar
ORIGINAL: PRO50SC
Thanks for the article Pro. Book marked that bad boy. I just changed the rear end fluids out to synthetic and put in new friction modifier.
Old 06-16-2007, 11:22 AM
5.0stanger
5.0stanger's Avatar
Mine will kick out every time...if I only had one tire spinning I would think there is something wrong. Maybe your spring is getting weak?
5.0stanger is offline
Old 06-16-2007, 11:40 AM
LTnone
LTnone's Avatar
I had mine rebuilt when I put the gears in. I had it made a bit stiffer (different configuration of the friction and reactor plates), but it'll kick sideways no matter what
LTnone is offline
Old 06-16-2007, 12:23 PM
keek89gt
keek89gt's Avatar
mine does the same thing....if im turning left and i give it...it will let loose but if im turning right...its just the one tire.....i thought there was something wrong with the rear end and i was actualy gonna post something about it lol....dont need to now
keek89gt is offline
Old 06-16-2007, 04:29 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
ORIGINAL: tmajikman
ORIGINAL: PRO50SC
Doing thatmay help you out.
PRO50SC is offline
Old 06-16-2007, 06:16 PM
HC_CrAzYHoRsE
Super Moderator
HC_CrAzYHoRsE's Avatar
you guys are weird[8D] ...the left tire disengages in turns, so if you turn left it will slide because all the weight/grip is going to the right tire wich is spinning... if you turn right it won't kick out as much because only the inside tire (right side) is spinning and the left is firmly planted... if both tires would spin, we'd all be in a ditch right now.
HC_CrAzYHoRsE is offline
Old 06-16-2007, 06:33 PM
tmajikman
tmajikman's Avatar
ORIGINAL: HC_CrAzYHoRsE
That was funny man.
jwog666
12-27-2021 08:09 PM
ChampInSD
10-02-2015 04:55 AM
mungodrums
09-28-2015 10:54 PM
folivier
09-26-2015 02:28 PM
lincolnshibuya
09-24-2015 10:46 PM
Quick Reply: wheel spin around a corner and from.....
