LCAs ...going out of my freakin' mind!!!!
#21
RE: LCAs ...going out of my freakin' mind!!!!
ORIGINAL: HC_CrAzYHoRsE
i loosened one of the h-pipe bolts and the hanger from the tip so it's out of the way enough to reach the bolt but i can't really wail on it with a hammer... i did figure an impact gun would make it alot easier but i don't have any.
ORIGINAL: Ze2222
I had the same problem easy solution is put a impact gun on the bolt and spin the **** until it breaks free, u will c all the rust n **** fall out.. If the exhaust is in ur way take off a couple of the rubber hangers just to drop it enough.. u'll c
#23
well i already loosened it a little with the breaker bar, i'm able to turn it with a hand ratchet if i force enough to be on the verge on an hernia so i'm pretty positive 230lbs will be enough, i'm just wondering if the impact and speed will be adequate to break the bolt loose from the metal sleeve.
#25
I've seen some electric impacts that were extremely strong, but air definitely owns. Sorry to hear about your problems dude, we feel for you though b/c we've all been there.
#26
u guys are obvioulsy not techs cuz any tech would of know about the snap-on 1/2 electric impact
ORIGINAL: OnyxCobra
#27
ORIGINAL: stocksuspension
ORIGINAL: OnyxCobra
#28
the bolts on the arms fuse to the bushing sleeve overthe years, it happend to me a few weeks back when i did mine and i just spun the bolt for several minutes with a 1/2" impact gun until it broke loose
#29
ORIGINAL: ZachW04Stang
Why would a "tech" waist there money on a electric impact when they have access to shop air? I've worked in plenty of shops, I've never seen anyone with an electric impact. Most guys use ingrassal gun with 730ft lbfwd torque, 1000ft lb reverse torque. One of the most powerful 1/2 guns out there.
ORIGINAL: OnyxCobra
#30
ORIGINAL: OnyxCobra
