Low oil sensor.
Old 06-16-2007, 06:56 PM
NYMustang50
NYMustang50's Avatar
Default Low oil sensor.
I dont think I have any oil leaks but my low oil sensor comes on could that be because I put in a high volume oil pump? Becuase I check it and its low but then later on like 20 min later it will be fine. Should this be something I should be worried about should I put like a oem oil pump in so that when I run the car at high rpm its not going to suck up no oil...?? I dont want it to suck up all the oil too quick that in high rpms theres none in the oil pan. Also my brakes squicke allot and there is meat on the pad so if I just get the rotors cut can I use the oil pads? Or do I have to put new pads in.
NYMustang50 is offline
Old 06-16-2007, 07:17 PM
NYMustang50
Default RE: Low oil sensor.
Should I try a thinner oil maybe? Maybe its so dirty now its getting cloged on the way down.
Old 06-16-2007, 09:36 PM
3904life
3904life's Avatar
dont use a HV pump unless u have a bigger oil pan the oem style will pump enough for alot of mods
3904life is offline
jwog666
12-27-2021 08:09 PM
CS2007
06-25-2019 09:45 PM
TCStangerv6
10-11-2015 05:57 PM
wraith777
09-28-2015 10:49 AM
Shadow7874
09-24-2015 09:06 PM
Quick Reply: Low oil sensor.
