gas sticking
gas sticking
so i was showing my car to my friend and when i was accelerating hard the gas stuck but not the petal and the rpms shot up and wouldn't go down so i had to shut my car off. no idea what it is but it's pissing me off cause it's happened a couple of times.
RE: gas sticking
check your TB. i have had a wire get pinched under it before. also make sure your floor mat is not making your pedal stick... i know you said its not the pedal but just check it because its so dumb it just may be the answer.
RE: gas sticking
this happend to me before.
there are two screws holding the throttle plate on. the top one snapped meaning the throttle could move forward but not backward.
dont ask me how it happend.. but it did
RE: gas sticking
my typhoon t/b use to do that but I sprayed the the butterfly w/ wd40 and also the springs in the lower part of the t/b and problem no more. I never had that problem w/ my bbk, its these $hitty typhoon t/b
BeatnikFink
10-01-2015 08:00 PM
