firing order question. help please!!!!
RE: firing order question. help please!!!!
i put a crown vic motor in my 95 gts and it has the 15426378 firing order ran fine as far as injector timing pretty sure that your cam has to be for that firing order not the 13726548
ORIGINAL: skinny_man18
like mattdel said the hall effect sensor in the distributor times the injectors the way the distributor is wired. i dunno if i explained that right but it did work for me. when i first put that motor in i wired it 13726548 and it only ran off four cylinders wired it correctly and it ran just fine. im not much of an electronic guy. im just tellin you this from experience, just ask mattdel or adder, buta 15426378 motor will run on a mustang computer
ORIGINAL: pro tint
so you didnt have to change the injector timing? how could that work. not saying it wont just curious.
ORIGINAL: Joel5.0
It will work in terms of being able to start the engine and run it.....but it will use a "waste injection" pattern in half of the cylinders screwing up A/F control. Simply read the article Ford Fuel Injection ยป Injector Firing Order? so you can understand the importance of having the spark and injectors firing order in sync.
ORIGINAL: pro tint
but will changing to a ho cam on a 15426378 firing order not mess up the valve timing with the storkes of the crank?
15426378 to 13726548 = 5 & 4 are now in exhaust cycle while 3 & 7 are in compression first, etc, etc.
