Supercharging Experts!!
I have a 306 with a cam and edelbrcok performer rpm heads and intake. i have a holley 750 vac secondarys carb. I am planning to buy a novi 1000 blower kit off ebay. What will i have to do to tune the carb for the novi??
thanks
thanks
RE: Supercharging Experts!!
http://www.holley.com/77-174FSBP-1.asp
forget about the novi. go either a holley, weiand blower. and mount the carb on top as normally done. and call it a day from there.
Both Holley and Demon(and others I'm sure) make blower carbs, that are properly calibrated to work with blow through forced induction, and have nitrophyl floats so they don't implode under the boost pressure. You're going to need a fuel pump that can put out higher pressure and a boost references fuel pressure regulator. You will need a different carb though, vac secondaries don't work well with blow through carb applications
u can modify most carbs for blow thru. I honestly don't know how but if u r really interested I have a teacher I can ask at school. It isn't too hard from what I remember. I don't see y u would need more fuel pressure because any carb can only take so much before ur flooding the needle n seat.
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
