still SD, what heads and cam???
ok, so my car is still speed density. i'm hesistant on converting to MAF because its like $500. anyway, i got a PP typhoon intake, which is identical to the edelbrock RPM if i remember right. i was wondering if i could put gt-40p heads on it and some sort of mild cam(not sure what kind) and still be good without having to convert to MAF???
RE: still SD, what heads and cam???
You sure can! Run whatever intake and heads you want then throw in a crower 11510. Its a awesome SD cam, loads of guys use it with no issues at all. All SD cams usually run a bit rich at idle, but the drivability is still kick ***. There is a few others you can chose from as well please see:
http://www.50tech.com/viewtopic.php?t=50694
There is lots of info there.
[/align]
[blockquote]
You sure can! Run the crower
[/align][/blockquote]
well, those heads and a cam will finish my main bolt ons. so will i be able to supercharge this in about a year and still keep it SD???
the cam i'm looking at is the crower 15510 or the comp cam xe264
ORIGINAL: 945LSTANG
i dont mean to hijack the thread but why not? ive heard the exact opposite.
ORIGINAL: AdderMk2
SD FTW.. never go MAF
where as SD is usually more accurate, adapts better to climate changes, and is a ton of fun to tune.
