just did a compression check!
RE: just did a compression check!
ORIGINAL: PRO50SC
Ummm, then how did you get the cam in and out?
ORIGINAL: pro tint
i didnt know you were suposed to remove them
ORIGINAL: HACKGT350
did you remember to put the push rods back in
ORIGINAL: pro tint
I thought that he meant for just the compression test. yes they are in there. the motor will run but mostly on cylinders 6&8
ORIGINAL: PRO50SC
ORIGINAL: pro tint
ORIGINAL: HACKGT350
ORIGINAL: 1985stang
...well obviously considering those are the only two you're getting compression on
ORIGINAL: pro tint
ORIGINAL: PRO50SC
ORIGINAL: pro tint
ORIGINAL: HACKGT350
ORIGINAL: pro tint
oil is nice and gold no smoke out the exhaust just ocasional back fires
ORIGINAL: LTnone
Blowin smoke? How's your oil looking?
-P.
ORIGINAL: pro tint
what could cause it to be soo off? also what should the compression normally be at (roughly)
ORIGINAL: PRO50SC
Judging from those #'s, the engine doesn't run correct? If it does, then you screwed up doing the test.
ORIGINAL: P Zero
Does it backfire out the exhaust or out the intake?
-P.
ORIGINAL: pro tint
ORIGINAL: LTnone
-P.
