is manually shifting an automatic good?
Old 06-20-2007, 03:05 AM
BlackBetty93GT
BlackBetty93GT's Avatar
Default is manually shifting an automatic good?
I know this is asked alot but is ti bad for the transmission to shift it manually when racing?
Someone said its not good cause it doesnt build up enough line pressure? What exactly does that mean?
BlackBetty93GT is offline
Old 06-20-2007, 03:07 AM
Mustangkiler
Mustangkiler's Avatar
Default RE: is manually shifting an automatic good?
The only reason to do that is if your kickdown isnt hooked up or you have the stock valve body in it still. Because you are not going to shift faster or the same each time then the transmission.
Mustangkiler is offline
AdderMk2
Banned
AdderMk2's Avatar
it means your probably gonna burn out your tranny
AdderMk2 is offline
Old 06-20-2007, 03:10 AM
BlackBetty93GT
so at the track i should just leave it in D
Old 06-20-2007, 03:12 AM
AdderMk2
Banned
AdderMk2's Avatar
pretty much...
unless you get a shift kit and manual VB
AdderMk2 is offline
cassidymustang
cassidymustang's Avatar
i knowsomepeople who live by it and have had no negitive results. isay put a shift kit in it and call it a day.
cassidymustang is offline
Old 06-20-2007, 03:14 AM
PX429
PX429's Avatar
Manually shifting an AOD is fine. On AOD's you can hold your rpm's longer. Whatever you do, do not "neutral drop"
PX429 is offline
Old 06-20-2007, 03:15 AM
ctgreddy
ctgreddy's Avatar
my tranny has a shift kit
so does that mean i can manually shift it with no concerns?
or should i still leave it in drive becasue it wont make any differance when i shift and when it shifts itself?
ctgreddy is offline
Old 06-20-2007, 03:18 AM
Mustangkiler
Leave it in drive, if you got one done right then when you hammer it , it should shift at around 5000 or 5500 and i dont know why anyone would want to rev a 5.0 any higher then that between shifts unless its a stroker.
Old 06-20-2007, 03:21 AM
cassidymustang
ORIGINAL: ctgreddy
you can but i wouldnt.
Quick Reply: is manually shifting an automatic good?
