Reverse then nothing....Help
Old 06-20-2007, 07:43 PM
cbstang92
cbstang92's Avatar
Default Reverse then nothing....Help
Hopefully one of you guys have seen this before. I have a 1992 Mustang GT, I figured since I was off today I would take it out. Went to the gas station, filled it up... put it in reverse backed up a little and then went to drive and its like there was nothing there, the shifter flows as free as can be, like nothing is attached cable wise or whatever method ford used. Sooo my stang is sitting up at a local gas station in reverse and will not do anything else.
the trans is an auto btw
Stranded mustang please help
cbstang92 is offline
Old 06-20-2007, 08:07 PM
mattdel
mattdel's Avatar
Default RE: Reverse then nothing....
is the transmission itself still in reverse, with the shifter showing drive?
if thats the case, the cable probably snapped somewhere. you can climb under the car and pull the shift lever forward two clicks, that will put you in drive
make sure someone is in the car pushing the brake, or pull your ebrake all the way up tight
mattdel is offline
Old 06-20-2007, 08:12 PM
cbstang92
cbstang92's Avatar
yes, the trans is still in reverse, you can turn on the key and move it back and forth freely and still stays in reverse
Old 06-20-2007, 08:15 PM
mattdel
mattdel's Avatar
yah, cable broke somewhere or it snapped off the shifter...
you are gonna have to crawl under there and move the shift arm to Drive yourself. 2 clicks from where it is.
mattdel is offline
Old 06-20-2007, 08:31 PM
samseed101
samseed101's Avatar
Or he could be lucky... maybe the cable didn't actually break and instead, the bolt holding it rusted or snapped out. Of course, none of us are ever that lucky
samseed101 is offline
Old 06-20-2007, 09:15 PM
tmajikman
tmajikman's Avatar
Make sure you shift to park or neutral to start the car first, then put it in drive and get it home.
tmajikman is offline
Old 06-20-2007, 09:51 PM
cbstang92
cbstang92's Avatar
just went up there and got it home, put it in OD and shifted fine all the way home. should i assume that its a snapped or disconnected cable?
Old 06-20-2007, 10:03 PM
tmajikman
tmajikman's Avatar
Definately, start checking where the shifter cable should connect as well as where the tranny cable should connect. The cable could have also snapped inside the plastic housing as well.
Old 08-27-2007, 08:14 PM
cbstang92
cbstang92's Avatar
is there any documentation on the net that anyone knows of so i can try and get this cable fixed? any help would be greatly appreciated
Gene K
10-21-2015 11:37 PM
foxdude
09-24-2015 08:45 PM
maestro1024
09-21-2015 02:40 PM
LivingInThePast
09-16-2015 12:20 PM
Pyrate Dave
09-10-2015 07:30 PM
Quick Reply: Reverse then nothing....Help
