Mid 12's Possible?
Mid 12's Possible?
i plan on getting AFR's 185 heads and a custom cam... with the mods in my sig and gasket matching the intake to the head will that get me to mid 12's? thanks...... yes i do have slicks and the 3.73's are coming in soon and Aluminum UDP's are too...
RE: Mid 12's Possible?
No. Your car won't even like the higher rpms unless you let it drink when it needs to. Bigger injectors, higher volume fuel pump, and a fuel pressure regulator need to be added to the list
Edit: and a tune, after the heads are on. Are you already planning on it? Mine was running a horrible a/f ratio before the tune, and picked up 60hp when it was screwed with.
