87 bronco motor
Old 06-23-2007, 05:58 PM
NYMustang50
NYMustang50's Avatar
Default 87 bronco motor
My friend just pulled a 87 bronco motor out of a bronco before giving it to a junk yard is the motor a HO? I want to put it in my mustang and I was wondering if it is a HO and if its a hydralic roller cam in it. It got a (not sure how long ago)newly fresh rebuild on it. Thats why I want to buy it. This why I know it will last allittle longer than the motor thats in my 89 now. Its 30 over and clean. its a 302 by the way or it was a 302..
NYMustang50 is offline
Old 06-23-2007, 06:53 PM
raven_ghostwolf
raven_ghostwolf's Avatar
Default RE: 87 bronco motor
Should be a roller cam, but I doubt it is a H.O. If it is anything like the 5.0 I pulled from the 87 LTD I'm using to build my new motor it is most likely the same as the 86 H.O. flat top pistons and E6 heads. But ifyour freind had it boredhe should know if it is a roller cam and what piston head combo is on it I would hope.
raven_ghostwolf is offline
Old 06-23-2007, 07:48 PM
sc94gt
sc94gt's Avatar
My dad had an 85 Bronco with a 351 in it and I remember it said H.O. on the air filter cover, not sure what the 302 was though.
sc94gt is offline
Old 06-23-2007, 09:58 PM
Skyler5.0
Skyler5.0's Avatar
i had few bronco's 351s and 302s my 87 was not a roller
Skyler5.0 is offline
Old 06-23-2007, 10:16 PM
F250sd
F250sd's Avatar
The truck 5.0's are not H.O's like the mustang is. They run the NON HO firing order and should be flat tappet cams. It should have the E7 heads as the 5.0 HO heads are truck heads. I wouldn't see a problem with usingthe long blockin a mustang if you were to swap in an HO spec cam (flat tappet would be just fine), and the proper oil pan/pick up.
F250sd is offline
Old 06-25-2007, 01:19 PM
NYMustang50
I plan on getting it and just using it as a long block. Those heads and stuff are probably in better condition then mine so. I will just put in a better cam though. If its flat tappet can I turn it into a hydro roller?
Old 06-27-2007, 08:16 PM
F250sd
F250sd's Avatar
You can chang it to a roller cam, but you can't use stock lifters for a 5.0 HO. You would haev to get lifters for retrofitting a non roller block.
F250sd is offline
firehorse02
11-16-2015 11:28 AM
UrS4
10-03-2015 06:23 AM
Explosive
10-02-2015 07:45 AM
Drastang
09-30-2015 03:48 AM
logan409
09-26-2015 07:43 PM
Quick Reply: 87 bronco motor
