heads, cam, rr's etc and a tune
Old 06-24-2007, 02:42 PM
1BIGMOFO
1BIGMOFO's Avatar
Default RE: heads, cam, rr's etc and a tune
alot of guys recomment a custom ground cam, what do you guys think? I only drive this car mabe once a week, only on nice days. I want a strong rough idle and an agressive cam. (mpg does not matter). Any preference.?
Also I checked ebay for scorpian rr's and no one has them for sale any more any suggestions? Thanks again guys..
I want to order this whole setup this week so any help would be appreciated.
1BIGMOFO is offline
Old 06-24-2007, 03:07 PM
w8less
w8less's Avatar
i know my old car sounded pretty mean but it didnt like it below 2000 rpms and really came alive from 3-65.
i would go custom there is nothing better than a cam made just for YOUR car.
w8less is offline
Old 06-24-2007, 03:37 PM
gt884me
gt884me's Avatar
Ive got an 88gt and I just bought AFRs 61cc stud mount, crane R.R.s mass air for 24lb, timing chain, lifters, pushrods, and the xe270hr-14 cam., Called AFR they said I wont have to notch my pistons, also said I probably wont have to upgrade my springs in the heads cause of my lift but they said it wouldnt hurt.
gt884me is offline
Old 06-24-2007, 03:50 PM
ckyguy68
ckyguy68's Avatar
But you also have to think... Is it worth spending an extra $150 on a custom cam when a good off the shelf brand is VERY similar? Im not saying its the wrong thing to do, but i would save my money.
ORIGINAL: Jasperstang308
ckyguy68 is offline
Old 06-24-2007, 03:58 PM
w8less
w8less's Avatar
but then the question is asked how do you know for sure which cam is right for you set up and car?
w8less is offline
Old 06-24-2007, 04:02 PM
MadMan@TheWheel
MadMan@TheWheel's Avatar
Got to Anderson Ford Motorsports, they have a TON of custom ground cams already on the shelf, and they will give you an idea about exactly what direction to go in. $299.00 even if they have to modify to fit your needs. Not bad if you ask me.
MadMan@TheWheel is offline
Old 06-24-2007, 04:09 PM
ckyguy68
ckyguy68's Avatar
I suppose the best way would be to ask people that have used a similar or same setup. It just seems more cost efficient, especially in this enviornment.
ckyguy68 is offline
Old 06-24-2007, 04:30 PM
w8less
w8less's Avatar
i suppose he could get a tf stg 1 cam like everyone else. it apears to be a descent street cam
w8less is offline
Old 06-24-2007, 11:45 PM
1BIGMOFO
1BIGMOFO's Avatar
well i dont want to notch my pistons for shure. i kindof just want it to all fall into place. isthere a place i can just get it all ? i want someone to tell me exactly what to get.. i know the general idea but not the nitty gritty stuff.. thanks
1BIGMOFO is offline
Old 06-25-2007, 01:12 AM
89saleen372
89saleen372's Avatar
A custom cam grinder is the best person to orchestrate your combination, IMO. If they know what heads you are using and what you want to use the car for, they can recommend what rockers and springs to go with their cam - based on your goals. Alternately, if you already have heads, rockers, and springs, they can factor the components into their grind. The cam is the key. Don't try to save $100 on this component and risk a bad combo. Cams are not a try and switch item. Again, IMHO.
89saleen372 is offline
Quick Reply: heads, cam, rr's etc and a tune
