Everything done DO I need to upgrade the stock maf?
Old 06-24-2007, 05:07 PM
sc2pwr
sc2pwr's Avatar
Default Everything done DO I need to upgrade the stock maf?
Ok I just bought this mustang off a buddy and here is the list of mods done to the car but it still has stock injectors and stock m.a.f (55mm). When does the stock one go static? I'm assuming it cant handle more then 260ish whp or around there. What kinda power should this motor be pushing? Brand new rebuild and runsgreat down low. above 5k it kinda dies. I checked the timing and it was at 14*. I'm not a newbie on cars but I am on this car. the ecuis set for 24lbs and cobra maf , Should I go bigger? [&:]
1) GT40 Intake manifold
2) GT40 heads
3) BBK 75mm Throttle body
4) Ford racing pistons & rods (9.8.1)
5) Bored . 30 over (306 now)
6) Flowmaster headers back
7) Two Random technology cats
8) Ford racing ECU
9)Stock MAF
10) 19lbs injectors
11) 3.55 gears
12) BFG Drag Radials (10 inch)
13) Ford racing C clip eliminator clips (rear end)
14) Cobra Short shifter
15) Brand new T-5 tranny
16) Ford racing flywheel
17) Ford racing clutch
18) MSD Ignition
19) B303 cam
20) Pulley kit (2 Piece)
21) Electric Radiator fan
22) Cobra Radiator
23)Ford racing Thermostat (160 open)
24) Walboro 255 High pressure
sc2pwr is offline
Old 06-24-2007, 08:33 PM
samseed101
samseed101's Avatar
Default RE: Everything done DO I need to upgrade the stock maf?
Well for one, your MAF should be bigger than your TB. You have it backwards, and by a large amount too.
samseed101 is offline
Old 06-24-2007, 08:52 PM
watson30
watson30's Avatar
What happens if you tb is bigger than your maf?
watson30 is offline
Old 06-24-2007, 09:20 PM
Grundy
Grundy's Avatar
same thing happens when you try to use a funnel backwards.
Grundy is offline
Old 06-24-2007, 10:10 PM
5.0stanger
5.0stanger's Avatar
I think your throttle body is too big(should get a 65 or 70 max) and you should pick up a 94/95 mustang 70mm MAF becuae your stock one is too small.
Also, if your computer is programed to run 24# and you have 19# in there, that is another problem.
5.0stanger is offline
Old 06-24-2007, 10:18 PM
nacanitihs
nacanitihs's Avatar
ORIGINAL: 5.0stanger
what he said
nacanitihs is offline
Old 06-24-2007, 10:25 PM
samseed101
samseed101's Avatar
ORIGINAL: nacanitihs
what he said
-2.
The Stock Ford MAFs are not calibrated for injector size. The calibration takes place in the computer. You can swap a stock cobra MAF for a stock GT MAF and you won't have any problems.
edited to add: Just noticed what you two meant. I thought you meant that he had 24# injectors, had the cobra computer set for 24# injectors, but was using a stock GT MAF. Turns out that the computer itself is calibrated for 24# injectors yet he is using 19# injectors.
I either misread that, or assumed that someone with even very little knowledge of the ford computer would know that that combo wouldn't work. Even if you know nothing about cars, that's almost a common sense math question... If the computer thinks that it can flow at 24#, so it opens and closes the injectors assuming that, then what do you think will happen if they are restricted and can only flow 19# an hour yet they only remain open for the same duration that they would have opened for 24# injectors?
Old 06-24-2007, 10:59 PM
sc2pwr
sc2pwr's Avatar
Ok agian , I just bought this car so thats why I'm asking these quistion's. The car is the way i bought it. I did run it this weekend and I ran a 13.59 @ 102.9 (2.0 60 foot ouch)with a passenger. we both weigh 240-250lbs. I just replaced the ecu with a stock one and I am going to purchase a 70mm maf (cobra). I hope I see a gain!!!
sc2pwr is offline
Old 06-24-2007, 11:09 PM
TTGreenSN95
TTGreenSN95's Avatar
ill sell you one for 30 bucks i have an extra one its 70mm
TTGreenSN95 is offline
Old 06-24-2007, 11:29 PM
sc2pwr
sc2pwr's Avatar
I'll take it!!!
sc2pwr is offline
Quick Reply: Everything done DO I need to upgrade the stock maf?
