trickflow 350 370 kit what injectors
RE: trickflow 350 370 kit what injectors
On my last foxbody i was intrested in TF top end kit and like you thought 30's were too much. I called their tech line and they said use 24's. Since you will have it apart an adj. fuel press. would be nice. If you plan on future upgrade go ahead and get the wahlbro 255 pump.
https://mustangforums.com/upfiles/70...86D36A0B18.jpg
[IMG]local://upfiles/70384/246555DAE88648E88B69ED7E325A5105.jpg[/IMG]
[IMG]local://upfiles/70384/F4BFF8AB4FDC410892C8161C67F877AA.jpg[/IMG]
If you upgrade your injectors, you should probably go with a bigger pump. I threw a Summit Brand (Walbro) 255 in mine since I was in there....
Since you are upgrading your pump/injectors, it would be nice to have the capability to adjust the pressure.....I use a BBK and an Autometer UltraLite Fuel Pressure Gauge.
thanks for the info guys now im just not sure on how much to increase fuel pressure or to leave it stock righ now for the nitrous i have to have min of 38 psi so 40 or 45?
24's is what they recommend. http://www.trickflow.com/product/enginekits/pr_enginesspecs_ford.asp
NOTE: Kits were dyno-tested on a 306 cubic inch engine with 9.5:1 compression, a 70mm throttle body, 24lb injectors, 190 lph fuel pump, mass air, and 10° base timing.
thats what it says on the website.
jwog666
12-27-2021 08:09 PM
