stock front spring height?
Old 06-27-2007, 10:07 PM
MEM 302 5.0L
MEM 302 5.0L's Avatar
Default stock front spring height?
ok so i just put some front springs out of an 84 GT into my 91 mustang, and it raised the front end up ALOT...it sits about 4-6 inches above the top of the front tire now....how high do your stock springs sit in the front?, or are these springs not stock that i got out of the 84...??
ok well thanks,
MEM
here are some pictures of what it looks like before i put the taller springs in and after....
[IMG]local://upfiles/47359/D580EA1ADEB74FDB9675CA93438222E5.jpg[/IMG]
[IMG]local://upfiles/47359/57D714D5BC0A4120A0B2611FBA10C0A5.jpg[/IMG]
[IMG]local://upfiles/47359/FEFF205D85104FB496A8DF75D860C26D.jpg[/IMG]
[IMG]local://upfiles/47359/411EC083BA8A458CA902ABD4BFB3B318.jpg[/IMG]
MEM 302 5.0L is offline
Old 06-27-2007, 10:34 PM
90mustang5.8
I ♥ Acer
90mustang5.8's Avatar
Default RE: stock front spring height?
sonce when did you paint your car[&:]
90mustang5.8 is offline
Old 06-27-2007, 10:35 PM
MEM 302 5.0L
its just primered right now....
im going to reprimer it with some good stuff then im going to repaint it the green that it used to be
idk why but i love that color..haha
Old 06-27-2007, 10:38 PM
blkonblk5.0
blkonblk5.0's Avatar
why did you take the old ones out?
blkonblk5.0 is offline
Old 06-27-2007, 10:43 PM
HC_CrAzYHoRsE
Super Moderator
HC_CrAzYHoRsE's Avatar
WHOA!! that's high!! lol i can't stop laughing for some reason, did you driveit around a bit? they'll usually settle a little, but dang, not THAT much.
HC_CrAzYHoRsE is offline
Old 06-27-2007, 10:48 PM
MEM 302 5.0L
havent driven it yet...just lowered it onto the ground and took a picture cuz it was so high.....
will it help to drive around a bit, and get an alignment? because i just changed the rotors, spindles, calipers, struts, and the sway bar ( my old one was rusted out reall bad and couldnt get the bolts out of it)....
Old 06-27-2007, 11:03 PM
raven_ghostwolf
raven_ghostwolf's Avatar
WHOA!! are you sure you got them seated in the a-arm correctly? but even then that is a lot of height! Sure it was an 84GT and not a 84 F150 4x4! Last Mustang I had sitting that high in the front didn't have an engine in it.
raven_ghostwolf is offline
Old 06-27-2007, 11:05 PM
MEM 302 5.0L
They are seated, and yes they were out of an 84 GT mustang.....are there any aftermarket springs that sit that high?
Old 06-27-2007, 11:12 PM
raven_ghostwolf
The only springs I had onmy Mustang that pushed my car up that high are the farmont wagon over-load spring I have in the rear of my car now that I cut down. Never see any Mustang springs for a fox do that.
Old 06-27-2007, 11:17 PM
MEM 302 5.0L
would they just be stiff from sitting in the 84 gt without the weight of a motor on it to push them down ..for over 3 years?
Quick Reply: stock front spring height?
