4 cylinder to 5.0 swap question??
ok I have a 92 mustangwith a 4 cylinder, now I did a motor swap and put a 5.0 in it but I never did change the under the dash wireharness will that materbecausenowI cant here the fuel pump or noting when the ignition is on! dose this mean that I have 2 get a new under the dash wire harness? [/align]any input will help thanks[/align]
RE: 4 cylinder to 5.0 swap question??
depends what year the engine harness is from, only certain years are compatable with each other
i'm not %100 and some one might correct me here, but the only engine harness that'll work with a 92 dash harness is either a 91 or 92 engine harness.
