question about TPS
06-29-2007, 02:42 AM
question about TPS
i cant figure it out but im running a 95mm vmas maf and a 95mm x 75mm accufab tb and after calibrating the tps to 0.96 my car started idling crazy and sputtered upon acceleration. since this calibration i cant get it to hold a good idle. i adjusted the idle all the way up and it still barely stays running. do i need to have my tune redone and chip reflased
06-29-2007, 02:44 AM
RE: question about TPS
what the hell kind of setup are you running to justify those parts
06-29-2007, 02:46 AM
306 with a holley systemax kit and a 4 inch power pipe, 24 lbs injectors.
06-29-2007, 02:49 AM
Banned
matt, its a 95mm maf and 75mm tb...
anyway.... the BS about setting the TPS to .96 volts needs to stop.
anywhere between .70 and 1 volt is fine
reset your ECM once your done.
06-29-2007, 02:54 AM
did that already and ecu reseting didnt help. wont run above or below fuel reg. set at 32 psi
06-29-2007, 09:10 AM
Dokilar
15
10-16-2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
