lug nut problem
Old 06-29-2007, 08:46 PM
crocop
crocop's Avatar
Default lug nut problem
i had to change the spring at the front of my 88. well after the spring was changed i put the wheel back on to the ?spindles? that the lug nuts bolt on to. well one the the spindles i guess was stripped or something because the lug nut would not want to go on. well i had to drive the car to get safety check and i didnt have tools to fix it so i just kept using the impact gun untill the lug nut went on. so now what are my options. can i take the lug nut off and use a tool to remake the threads? any help would be great.
crocop is offline
Old 06-29-2007, 08:47 PM
Pearlkobra12
Pearlkobra12's Avatar
Default RE: lug nut problem
your gonna have to take the axles out and have a new stud pressed in
Pearlkobra12 is offline
Old 06-29-2007, 08:50 PM
SteveSkal
SteveSkal's Avatar
Well the wheel stud on your car is pressend into the rotor so all you have to do (once you use that impact gun to take that lug back off) is bang out that wheel stud and put a new one on. Not that big a deal, I mean if you changed your own spring then this shouldn't be much of a challenge.
SteveSkal is offline
Old 06-29-2007, 08:54 PM
crocop
crocop's Avatar
so i take out the lug nut then bang that stud with a hammer or probably rubber mallet and it should come out. how do you install a fresh one, and can i go to a auto parts store and order one or do i have to et a used one?
crocop is offline
Old 06-29-2007, 09:03 PM
SteveSkal
SteveSkal's Avatar
You can go to the auto parts store and get one. just push it through thr back of the rotor and when your installing the tire and lug, the lug will pull the stud through as you are tightening it.
10-07-2015 07:02 PM
kachuy10
09-22-2015 01:27 PM
maestro1024
09-21-2015 02:40 PM
stangin1996gt
09-21-2015 11:01 AM
Big Al's 03
Mach 1 Section
09-21-2015 07:59 AM
Quick Reply: lug nut problem
