Doug tuning Fox bodies?
Yes, at least one. For anyone that has followed my 86 GT. I has always made big HP but the A/F has been way messed up and nothing seemed to fix it.
With the help of Walker Dyno Tune and Doug at Bama Chips, the A/F is now what it should be.
I reduced the boost by 5# from my last numbers because the A/F just wasn't right.
On the dyno last night it made 600 RWHP behind the C4 and from tip in to 6500 RPM the RWTQ stayed over 450. The peak RWTQ was over 500 but can you imagine how 500 at tip in and staying over 450 RWTQ all the way to 6500 RPM is going to feel.
Thanks Doug, Blake, and PJ!
RE: Doug tuning Fox bodies?
ORIGINAL: Jasperstang308
stock block?
is this the drag car or another?
stock block?
Went back to 20# pulley last night for a test pull on it, RWHP was up 100 for the pull up to 5000 RPM. Looks like the 20# pulley will require Doug to do a little more tuning (tried to go lean).
I hope to be at the track next weekend. Some may remember this car was running 6.30@110mph before I started messing with it. New fuel lines, new rails, bigger injectors, regulator, etc only seemed to slow it down to 6.50 due to rich in bottom end. The current effort is to flatten that A/F from bottom end to top end.
your car is freakish thats a lot of hp and all on a stock block with a lot of work to to well make it work
Luke9222
10-22-2015 11:55 PM
