WOT switch
RE: WOT switch
no dont do that,i JUST mounted mine tonight.
take off your iac and intake tube(just so u can see and have some room), then the bottom nut off of the tb.
dont mount the switch perpendicular or parallel on the bracket, do it at an angle... the longer point of the lever on the switch facing towards the tb. directions said to bend the bracket in the middle 70* but that did not work for me, i ended up cutting the 1st oval out of it, and using the middle one to bolt it up. bent it so that it would touch when WOT and i was done... went easier then i thought it would. if you really need it i can get you a pic tomorrow
RE: WOT switch
ORIGINAL: dimebag
RE: WOT switch
ORIGINAL: dimebag
i used the adapter that came with my fuel pressure guage, it just happened to be the right size for everything.
and yea illl try to remember to get that pic tomorrow
got ne picutres??
RE: WOT switch
ORIGINAL: dimebag
shyt man i forgot all about gettin you a pic, my bad... its dark now... ****.
RE: WOT switch
ORIGINAL: dimebag
to dark? na man not too dark, lol im just in for dinner... gonna go back out here soon and finnish up the window switch
