TIMING AND FUEL PRESS. PROBLEM
Old 07-01-2007, 10:00 AM
kl92gt
kl92gt's Avatar
Default TIMING AND FUEL PRESS. PROBLEM
i just got my motor 2gether and when setting the timing it doesnt advance when you give it gas any ideas. and when i first got my car running the fuel press. was fine but now sometimes it will stay at 20psi and take a real long time to come up to 40 then other times it will be fine the pump is new and the regulator is almost new bbk regulator and walbro pump and one have any ideas
kl92gt is offline
Old 07-01-2007, 10:05 AM
kl92gt
kl92gt's Avatar
Default RE: TIMING AND FUEL PRESS. PROBLEM
also after i take the car down the street and shut it off sometimes it wont start up it throws a lot of fuel at it and wont start i have to floor it to get it to start i pulled codes and got one for map sensor, coolant temp sensor (its removed cuz i have a mechanical autometer), and o2 sensor faulty i have a c&l mass air ive heard ppl having this problem and changing to a proM and it fixes it any ideas
kl92gt is offline
Old 07-01-2007, 10:43 AM
luckythirteen13
luckythirteen13's Avatar
id switch to pmas if i was you. not saying that it will fix your problem but the c&l is junk.
did you remember to put the spout connector back in? if not, that will stop the timing from advancing.
do you know for a fact the pressure gauge is working. if the car runs fine when the fuel pressure is at 20psi then your gauge is bad because 20psi isnt enough pressure for the injectors to atomize the fuel correctly. with the fuel not being atomized right the motor would hardly run
luckythirteen13 is offline
Old 07-01-2007, 10:50 AM
kl92gt
kl92gt's Avatar
yea ive been thinking about geting rid of the c&l yea the spout cnnector is back in the guage is a mechanical autometer fuel press. it runs on 20psi it doesnt run to bad either could it be air in the line or something throwing he guage off sometimes?
kl92gt is offline
Old 07-01-2007, 10:58 AM
luckythirteen13
ORIGINAL: kl92gt
its possible. my mechanical edlebrock fuel pressure gauge did the same thing for a couple weeks and then it started working fine again. i new it was the gauge acting up because the car ran fine. plus, if the you hear the fuel pump go on, it will spin till you hit full psi when you first turn the key. so when the pump stops you have full pressure in the fuel system
Old 07-01-2007, 04:15 PM
kl92gt
kl92gt's Avatar
i found the problem i had a superchip in the car and i just pulled it out and its fine now
kl92gt is offline
djbigskrilla
09-20-2022 01:04 AM
mstahoo
SVT Forums
08-19-2021 09:15 PM
ShaneB26154
35
03-04-2021 04:05 AM
timeformiller44
08-26-2015 12:03 PM
1st 4 eyed fox
08-24-2015 06:56 PM
Quick Reply: TIMING AND FUEL PRESS. PROBLEM
