Will this breather fit?
Old 07-01-2007, 02:19 PM
92hatchLX
92hatchLX's Avatar
Default Will this breather fit?
Hey guys, does anyone know if this breather will just push right down into my stock filler neck?
http://store.summitracing.com/partde...p;autoview=sku
If not, which ones are some of you using? I'd like to find one with the 5.0 or Ford or something on it. Thanks!
92hatchLX is offline
Old 07-01-2007, 02:41 PM
Joel5.0
Joel5.0's Avatar
Default RE: Will this breather fit?
If you have the PCV system working......you don't want an open breather installed...it will cause a case of unmetered air = vacuum leak ......just a thought.
Joel5.0 is offline
Old 07-01-2007, 02:58 PM
luckythirteen13
luckythirteen13's Avatar
arent all breathers the same diameter as far the fitment goes? every breather i have every used fit no problems. if it was an unusual size i would think they would provide a rubber grommit that would work with it
luckythirteen13 is offline
Old 07-02-2007, 12:36 PM
ruger311
ruger311's Avatar
get a screw in one from ford racing
ruger311 is offline
Old 07-02-2007, 12:51 PM
samseed101
samseed101's Avatar
No it wont fit. That is a push in breather and it wont fit in the stock oil filler tube. If you want to run that, you need a valve cover with a standard grommet, which I believe it's going to be a 1.22" inside diameter, 1.25" outside diameter... but don't quote me on that.
But I have to ask... why are you trying to run an open breather on an EFI engine with a working PCV system?
samseed101 is offline
jwog666
12-27-2021 08:09 PM
mustangheaven
01-03-2016 11:20 AM
BeatnikFink
10-01-2015 08:00 PM
fastbackford351
10-01-2015 12:24 PM
mdg
10-01-2015 07:04 AM
Quick Reply: Will this breather fit?
