starting a sitting 5.0
Old 07-02-2007, 12:42 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: starting a sitting 5.0
Just charge the battery and fire it up!! it'll either go or blow!!! if it starts check under the car immidiately and look for potential leaks. good luck!!!
mjr46 is offline
Old 07-03-2007, 01:36 PM
Jfsram
Jfsram's Avatar
Another vote for pulling the distrubutor and priming the oil pump with a drill. This will pressurize the bearings with oil. Instant pressure at start up.
The starter method takes too long to get pressure and in the meantime. The cylinders and rings have no lubrication because the engine needs to be running to lube those.
Jfsram is offline
djbigskrilla
09-20-2022 01:04 AM
drfister
05-03-2018 10:38 PM
1st 4 eyed fox
08-24-2015 06:56 PM
jjwinel78
08-17-2015 03:34 PM
cvarner131
08-17-2015 07:38 AM
Quick Reply: starting a sitting 5.0
