starting a sitting 5.0
Old 07-01-2007, 02:56 PM
50conv
50conv's Avatar
Default starting a sitting 5.0
what should i do before i try to start up my 5.o thats ben sitting for about 2 yrs. 1990, automatic.
50conv is offline
Old 07-01-2007, 02:59 PM
luckythirteen13
luckythirteen13's Avatar
Default RE: starting a sitting 5.0
change the plugs, oil, coolant, drain the fuel out and put in new stuff. check the tranny oil.
luckythirteen13 is offline
Old 07-01-2007, 03:00 PM
50conv
50conv's Avatar
thank you sir
50conv is offline
Old 07-01-2007, 03:14 PM
OnyxCobra
OnyxCobra's Avatar
before i start mine every year i unplug the coil and turn the engine over to let the oil pump up through the engine, then i reconnect the coil and fire it.
OnyxCobra is offline
Old 07-01-2007, 03:20 PM
luckythirteen13
onyxcobra reminded me of something. get a breaker bar and turn the motor over by hand to make sure its not seized or hydro locked.
Old 07-01-2007, 03:22 PM
50conv
50conv's Avatar
alright guys, appreciate your help
50conv is offline
Old 07-01-2007, 05:08 PM
angcobra
angcobra's Avatar
ORIGINAL: OnyxCobra
I am not real fond of that method especially if you have aftermarket high energy ignition. This really turns the oil pump to slow to get the oil there very fast and you can burn out ignition components with the coil wire out.
If you are really concerned about lubrication from a long setup, then put a little 3 in 1 oil in the cylinders through the plug holes and remove the distributor and use a socket with speed handle/drill to turn the oil pump shaft. Then rotate the engine by hand/pull handle several rotations and then prime the oil pump again. Put the distributor and plugs back in, hook up the wires and give it a try.
Fuel is another concern, two years is too long without fuel stabilizer, drain the fuel before powering up the fuel pump. If you know it will sit for a while, add fuel stabilizer to the last full tank.
angcobra is offline
Old 07-01-2007, 05:25 PM
50conv
50conv's Avatar
thanks angcobra, appreciate it man.
50conv is offline
Old 07-01-2007, 05:28 PM
OnyxCobra
OnyxCobra's Avatar
ORIGINAL: angcobra
ORIGINAL: OnyxCobra
really? never thought of that. It definitely turns it over faster than u can by hand, though. an oil pump primer would be ideal.
Old 07-01-2007, 06:00 PM
keek89gt
keek89gt's Avatar
if u want you could also remove the distributor and turn the oil pump manually without have to crank the motor over...that is what i would do
keek89gt is offline
Quick Reply: starting a sitting 5.0
