stripped !$@#$ bolt
Old 07-02-2007, 12:58 AM
stocksuspension
stocksuspension's Avatar
Default RE: stripped !$@#$ bolt
its not a 1/2 inch!! its a 13mm, thats y i dont use craftsman tools there incosistent, dont try to cut if of or any of the mickey mouse **** anyone in this forum will suggest, just go buy a bolt out set and thats it, no more headache
stocksuspension is offline
Old 07-02-2007, 01:05 AM
Maxwelhse
Maxwelhse's Avatar
Left handed drill might work too... Should cost ya all of about $10 if you can find one...
Maxwelhse is offline
Old 07-02-2007, 01:10 AM
Shelty
Shelty's Avatar
stock suspension, when I fit the 13 mm over it (when trying to find the size, it was too loose, and I tried it with two different makes of wrenches, and all the other bolts came out with either the breaker bar or good old muscle. this last one for some reason said "fug you Biotch!"
hack told me of a type of socket that is designed to fit stripped heads...
its not stripped too horribly, just enough to cause the wrench to slip off...
Shelty is offline
Old 07-02-2007, 01:19 AM
my77stang
my77stang's Avatar
is a 6 point slipping off it? as suggested, heat is your friend. get that fugger red hot and shoot some pb blaster on the threads since you said you can see the backside of the bolt
my77stang is offline
Old 07-02-2007, 01:23 AM
Shelty
Shelty's Avatar
yeah its a 6 pt. pb blaster? never heard of it
Shelty is offline
Old 07-02-2007, 02:31 AM
FuzzyDiceRule
FuzzyDiceRule's Avatar
buy a grinder...
FuzzyDiceRule is offline
Old 07-02-2007, 08:48 AM
85 Stang
85 Stang's Avatar
PB is a penetrating oil works magic just let it soak in.
85 Stang is offline
Old 07-02-2007, 10:05 AM
hellion_79
hellion_79's Avatar
what about vy-scripts?? have you tried that??
hellion_79 is offline
Old 07-02-2007, 11:39 AM
AdderMk2
Banned
AdderMk2's Avatar
throw your entire tool set in the garbage and sell the car. you obviously dont have a clue what your doing,
anyone with any intelligence wouldnt have put an open end wrench on it... that was just dumb
AdderMk2 is offline
Old 07-02-2007, 12:25 PM
hatchdemon89
hatchdemon89's Avatar
i know this thread is a lil old but try shaving the head of the bolt so u can use a flat head tip an use a electric drill an an do it that way worked for me
hatchdemon89 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
baddog671
07-26-2016 01:20 PM
wraith777
09-28-2015 10:49 AM
GLOCKer
09-28-2015 07:36 AM
2poor4u2
09-26-2015 11:08 AM
Quick Reply: stripped !$@#$ bolt
