Rockers
RE: Rockers
hey i think i just posted those LOL.... they will work just fine, i actually like them alot because they have the white plastic inserts that the pushrods rub against instead of metal.
im not sure, but with those you may not even need new pushrods
RE: Rockers
ORIGINAL: AdderMk2
wow your stupid....
1993-1995Cobra's came stock with 1.7 FULL roller rockers. and they do bolt directly onto stock GT heads
You need to make sure they are PEDESTAL mount rockers, but yes, they will hit your valbe covers unless you remove the oil baffles
ORIGINAL: 88stangaruu
But the stock heads arn't designed to work with roller rockers, you need studs to mount them on, the stock heads have just a screw to hold the rocker arms down with.
wow, what a f(ckin *******. I was assuming he was refering to the stud mounted roller rockers you *****. Because if you really read the question, yea, thats kinda what it sounds like to me, doesn't though?
Damn this site has changed, last time i logged on somebody would have politely corrected you instead of being a f(ck head and calling someone stupid for a mis-interpretation, because thats what it was.
RE: Rockers
ORIGINAL: kevman41635
No adder i asked about stud not roller i know i can use roller
I have a 94 5.0 5 speed and i was wanting to know will 1.6 or 1.7 rockers work with out any moding to the vavle covers or rods or anything like that
RE: Rockers
[/quote]No adder i asked about stud not roller i know i can use roller [/quote]
see, thats what i thought, you seemed to ask if you could just throw some studs in your heads and then put some like Comp Magnum roller rockers on, thats what i was assuming. Thanks for clearing that up.
tisk, tisk, tisk.
Now back to you *****, see what i mean now? So next time before you go calling someone f*ckin stupid you should take the time and read the f*ckin question, now who's the big throbbing d(ck in the room?
[sm=icon_rtfm.gif]
ORIGINAL: AdderMk2
he didnt ask anything about stud mount rockers... he hasked if he could use roller rockers...
so its not that you misinterperated it... your just wrong
[sm=icon_rtfm.gif]
RE: Rockers
yea most of the time, when people ask about roller rockers, they want a true roller rocker, not a bolt down type with a roller tip adder. A 93-95 cobra rocker arm isn't the first thing that pops into my head when you mention a roller rocker, sorry.
So go ahead and attack me and Kevman because your an ******* and you know you were in the wrong straight up calling somebody stupid for answering a question in a different manner than you thought to be right.
Ok, yes, the cobra's did come with roller tipped rocker arms, but in the true sense of a roller rocker, which he was refering to (i.e. an aluminum or steel cast roller tipped, needle bearing rocker arm) he couldn't just throw those onto stock E7's.
