Rockers
Old 07-02-2007, 11:30 AM
kevman41635
kevman41635's Avatar
Default Rockers
I have a 94 5.0 5 speed and i was wanting to know will 1.6 or 1.7 rockers work with out any moding to the vavle covers or rods or anything like that
kevman41635 is offline
Old 07-02-2007, 11:46 AM
88stangaruu
88stangaruu's Avatar
Default RE: Rockers
If you can find 1.7's in the stamped type deal, yea, you probably could get away without having to do anything to the pushrods, etc.
But the stock heads arn't designed to work with roller rockers, you need studs to mount them on, the stock heads have just a screw to hold the rocker arms down with.
88stangaruu is offline
Old 07-02-2007, 11:52 AM
AdderMk2
Banned
AdderMk2's Avatar
Default RE: Rockers
ORIGINAL: 88stangaruu
wow your stupid....
1993-1995Cobra's came stock with 1.7 FULL roller rockers. and they do bolt directly onto stock GT heads
You need to make sure they are PEDESTAL mount rockers, but yes, they will hit your valbe covers unless you remove the oil baffles
AdderMk2 is offline
Old 07-02-2007, 12:01 PM
Gary H
Gary H's Avatar
Default RE: Rockers
They make pedestal mount rocker roller rockers too. 94-95 valve covers are lower than the 86-93 though, I think. The cobra's came with 1.7 roller rockersbut I'm not sure if they used the same V/C as the regular 5.0
Gary H is offline
Old 07-02-2007, 12:50 PM
kevman41635
Default RE: Rockers
Will these work they are 1.7 Non Rail 3/8 Nut
Thanks for the help guys
[IMG]local://upfiles/27439/3B4BEDC74EBA4E6EAD98BDB548621B73.jpg[/IMG]
Old 07-02-2007, 01:00 PM
Gary H
Gary H's Avatar
Default RE: Rockers
Nope, you need this
http://www.jegs.com/webapp/wcs/store...58806_-1_10231
part # 397-M-6564-A50 or 397-M-6564-B351 will work as well as a couple others
FWIW, crane makes the cobra 1.7 rocker arms.
Gary H is offline
Old 07-02-2007, 01:04 PM
my77stang
my77stang's Avatar
Default RE: Rockers
or these
http://store.summitracing.com/partde...p;autoview=sku
my77stang is offline
Old 07-02-2007, 01:05 PM
P Zero
P Zero's Avatar
Default RE: Rockers
And some new valve covers.
-P.
P Zero is offline
Old 07-02-2007, 01:08 PM
kevman41635
Default RE: Rockers
Does anyone know how well these work Crane Rocker Arm Guideplate Conversion Kits
Old 07-02-2007, 01:12 PM
kevman41635
Default RE: Rockers
So as long as they are not stud they will work because that means that they are pedestal-mount
Thanks
Quick Reply: Rockers
