Doing the fuel pump at home, any suggestions?
I've replaced many intank fuel pumps at work. But there I have a lift and a gas tank/tranny jack. I don't work today and I figured that it would be the perfect day to get my 255lph Walbrofuel pump swapped in. Any suggestion onhow I should usethe floor jack to support my fuel tank? Anyone have any tips or tricks for doing this without a larger jack?
RE: Doing the fuel pump at home, any suggestions?
if the tank has more than a couple gallons in it, i suggest using a plank of wood inbetween the jack and the tank.
when i did my pump, i put the car on ramps, and when i unbolted the tank, i just let it sit on my chest.
ORIGINAL: mattdel
empty the tank slide under it let it fall ontop of you, thats what I did. disconnect the wires and you are ready to swap it out. Put it in the same way you got it out. I used my forearm for leverage and held it in the air while i threaded the strap bolts back in. It was a little bit of a pain but not too much. not like installing LONG TUBE HEADERS....stupid longtubes...
I was almost done until I discovered that the fuel tank grommet (the one that the filler neck goes through when it goes into the tank) was dry rotted and torn up. I called my work and they're going to get one from one of the Ford dealerships. Otherwise I would've been done by now lol. Oh well **** happens, I'll have my new grommet at around 1 o'clock today and she'll be running.
I didn't break the seal, it's just been torn up over time. I also checked the baffle andit looked good. The Walbro pump is a lot quieter than the stock one. It doesn't make that whining sound but you can still hear it turn on, I've had people tell me that they are really noisy.
TfcCDR
09-14-2015 12:08 PM
