Serpentine Belt Too Tight??????
Old 07-02-2007, 09:14 PM
only90s
only90s's Avatar
Default Serpentine Belt Too Tight??????
My serpentine belt squeeks a little bit when cold, then once the engine warms up it seems to go away...
Do the belts stretch a little when they get warm?
Am I loosing power if the belt is too tight?
only90s is offline
Old 07-02-2007, 09:16 PM
only90s
only90s's Avatar
Default RE: Serpentine Belt Too Tight??????
I should add I deleted the AC...am running a 93 Cobra water pump pulley and the stock tensioner.....there is barely any room between the belt under the tensioner and the water pump...
only90s is offline
Old 07-03-2007, 12:20 AM
LTnone
LTnone's Avatar
Not really gonna lose power, the accessories would spin with the same resistance if the belt was perfect (no slip). Pretty hard to get one on there "too" tight anyway, though. I think there's some junk that you can put on the belt to keep it from squealing, is it an old belt?
And I think that squeak is really more of a whine, perhaps coming from that odd piece of plumbing that has attached itself to the passenger side of your motor
LTnone is offline
Old 07-03-2007, 12:52 AM
ALMOST STOCK
ALMOST STOCK's Avatar
IF you're using the stock tensionerit will give you a good reading ifthe belt isto tight or long.
ALMOST STOCK is offline
Old 07-03-2007, 01:04 AM
will
will's Avatar
Could be the alt charging the battery up, mine does the same thing a block away it stops. It's not a loud squeel just loud enough to make you mad.
will is offline
Old 07-03-2007, 10:19 AM
only90s
only90s's Avatar
Thanks guys...I have a much better understanding of that silly belt and the tensioner now...It held up on the dyno at 6k rpms so I guess it is OK...
only90s is offline
Old 07-04-2007, 02:34 PM
Jfsram
Jfsram's Avatar
If the belt is too long or worn enough. The tensioner can bottom out and offer not additional tension. Then the belt will be essentially too loose and may squeal. Worse scenario would be a loaded accessory and the engine ramping up in rpms.
Jfsram is offline
Old 07-04-2007, 05:47 PM
luckythirteen13
luckythirteen13's Avatar
it squeaks when you first start it up because the belt is old. the belt is slipping which is the noise you hear. after a few seconds of slipping the belt gets hot and a little sticky it then grabs the pulley it was slipping on causing the sound to go away
luckythirteen13 is offline
Old 07-05-2007, 05:31 AM
AdderMk2
Banned
AdderMk2's Avatar
too tight of a belt and you will wear out the bearing in your alternator
AdderMk2 is offline
mrtrodonet
09-19-2020 03:12 PM
bradleyb
11-27-2015 07:50 PM
folivier
Tennessee Regional Chapter
10-02-2015 05:32 AM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
Quick Reply: Serpentine Belt Too Tight??????
