Selonoid troubles?
Old 07-03-2007, 12:18 AM
joshua029
joshua029's Avatar
Default Selonoid troubles?
Alrighty, the other day i had just gotten off work and i tried to start my mustang. I clicked rapidly and loudly for a couple seconds when i tried to start it and then i quit. I tried again and the interior lights came on, and the clock on my radio was reset tonoon but the dash clock was still at the right time.
I cleaned the terminals for the battery, had the battery checked at autozone and they said it was great, check the alternator when it was running so its not it and it wanted to start when the problem was going on so i dont think thats it. The guy at autozone said it was the selonoid and gave me one but im not sure which one it goes to.
Could this be the problem? if so how many are there and where are they?
starter and alternator?
joshua029 is offline
Old 07-03-2007, 12:32 AM
mattdel
mattdel's Avatar
Default RE: Selonoid troubles?
no, just one solenoid, right next to the coil.
if you still have a black plastic cover under the hood, on the drivers side, with the Catalyst sticker on it, its under that cover, right behind the battery.
MAKE SURE that you re-install the wiring the exact same way that you take it off the old one, and make sure that the mounting surface is clean, it is the ground for the unit.
mattdel is offline
Old 07-03-2007, 12:38 AM
ALMOST STOCK
ALMOST STOCK's Avatar
I wouldn't rule out theAlt or Starter though if it were me.
ALMOST STOCK is offline
Old 07-03-2007, 12:48 AM
mattdel
mattdel's Avatar
could be the starter, yes, but you already have the solenoid, so try it out. its the cheaper of the two, and a little reassurance anyway, regardless.
mattdel is offline
Old 07-03-2007, 12:57 AM
joshua029
joshua029's Avatar
were talking about an sn95 just in case that makes any difference in this situation.
my haynes manual says that there is more than just that. is there a way you could show me a pic or something of where it is at exactly?
Old 07-03-2007, 01:02 AM
ALMOST STOCK
ORIGINAL: mattdel
X2
mattdel
mattdel's Avatar
yah sn95's are different, couldn't tell ya if there is a second one.
the starter solenoid is mounted on your starter.
mattdel is offline
CS2007
06-25-2019 09:45 PM
msavoia23
12
07-07-2018 12:08 PM
chrisdbassplayer
10-13-2015 06:53 PM
ChampInSD
10-02-2015 04:55 AM
TorinoCobra070
SVT Forums
09-18-2015 10:34 AM
Quick Reply: Selonoid troubles?
