I want to find out what type of options I might have on my frame. I noticed my drivers side front tire is about an inch farther back than my passenger side front tire, is there any adjustment or anything I could try or use to fix this issue. Thanks in advance.
If it just the tire check the suspension parts. Also check the K-member. If it is the frame you could have it pulled or redo it using square tubing stock.
It seems to be just the tire, I can tell that it was hit in the front corner but can't see anything on the frame that is bent, other than the front tire being an inch back to far. What would the frame cost to be pulled?
actually it drives straght down the road, is there any way a ball joint could create this problem. What do you think will be the problem more than likely, just a guess? It does track kind of weird sometimes when I drive.
