Nitrous gurus, need some help!
Old 07-04-2007, 02:07 AM
  #21
kdizzle711
kdizzle711's Avatar
Default RE: Nitrous gurus, need some help!
I'll up the fuel pressure a little bit,I think it is a tad below 38 at wot. The pump is a 255lph pump and I have 30lb injectors, so that isnt it lol. Thanks for all the help. If it keeps backfiring tomorow on my way to work ( I work at a dealership) I'll have one of the mechanics throw some new plugs in it and a new cap.
kdizzle711 is offline
Old 07-04-2007, 02:27 AM
  #22
FullAuto
FullAuto's Avatar
ORIGINAL: 89 fox
plus if you have the 6a...try gapping to .050
Who in the hell told you that?[sm=boosign.gif]
FullAuto is offline
Old 07-04-2007, 02:38 AM
  #23
kdizzle711
kdizzle711's Avatar
Give me some insight full auto, your the nitrous dealer, lol. What do you think my problem is and what should the plugs be gapped at. Right now there autolite3924's gapped .035 with an msd 6a
Old 07-04-2007, 02:47 AM
  #24
FullAuto
FullAuto's Avatar
ORIGINAL: kdizzle711
I'd leave the gap there. Personally, I'd still run a 3925 with only an 80hp shot, but the heat range isn't the problem. Other than Nitrous Works being a cheap kit, there is something else giving you problems. There are way too many variables for me to play doctor over the internet. But gapping the plugs to .050 is not the answer. I think he's probably spraying pretty small to get away with that.I can't seeany manufacturer recommending that.
FullAuto is offline
Old 07-04-2007, 02:49 AM
  #25
kdizzle711
kdizzle711's Avatar
Well I was building up to a bigger shot, thats why I have the colder plug. Any ideas what it could be?
Old 07-04-2007, 02:50 AM
  #26
FullAuto
FullAuto's Avatar
Is it really a backfire or is it detonation? I usually don't hear people describe it as "some backfire". Usually you get ONE backfire and then you're either putting your intake tube back on or sweeping up parts.
FullAuto is offline
Old 07-04-2007, 02:53 AM
  #27
kdizzle711
kdizzle711's Avatar
Lol I don't think it is detonation. It is getting plently of fuel.
Old 07-04-2007, 02:57 AM
  #28
dimebag
dimebag's Avatar
i just installed my ****.... dont think it pulls hard? yea my 75 jets didnt feel too hard, but the 100s is a whole new story. the backfire is either a spark getting blown out, which i think is not the case.... or a lean condition, i vote that. i dont think your getting the fuel you need.... list all your mods, including what size injectors.. and do you have an adjustable fuel press. regulator?
dimebag is offline
Old 07-04-2007, 02:58 AM
  #29
FullAuto
FullAuto's Avatar
That doesn't mean it isn't detonation. Also 8* is way too retarded. You should be at 12-14*.
FullAuto is offline
Old 07-04-2007, 03:00 AM
  #30
kdizzle711
kdizzle711's Avatar
It is a 331 stroker, trickflow twisted wedge heads, trickflow stage 2 cam, trickflow upper and lower, anderson power pipe, 30lbs injectors, 255lph fuel pump, etc. I do have an adjustable fuel pressure regulator and I set it to 38psi before I sprayed it but I think it might have dropped down a little below 38 while tightening it down.
Quick Reply: Nitrous gurus, need some help!
