Nitrous gurus, need some help!
#42
RE: Nitrous gurus, need some help!
I'm in other threads trying to make a sale. Some guy was about to pay $100 too much for a kit from Summit. LOL
Anyway, try 42psi. Either start pulling plugs and reading them or put it on a dyno and check a/f ratio. I usually run 41-42psi, but again, every combo is different.
#45
I run a 75 shot, an 12° timing, 43psi no vac fuel pressure, on the stock tune. And I'm usually pulling 11.5-12:1 on my wideband. Never get any popping.
However, I also run a .45 gap on my plugs. They never get burned, come out a nice red/brown color.
best question is.... hows your bottle pressure?
#47
definitly, you gap is WAY too small, but I wouldnt run it at .050 like mentioned before. go to about 40-45 and see what happens...
and do you actualy have a gauge, or are you just guessing that your pressure is at 1000 because its full
#48
you should get a warmer for your bottle. When you actually get it tuned right, its going to be like night and day difference.
Ive actually took my bottle and run scalding hot bath water in my tub, let the bottle set then wrapped it up in tin foil and drove to the local street racing spot like that. Stayed warm to, but i used an entire roll of tin foil. [:-]
Cavedawg
09-17-2015 09:51 AM
