Soild lift, Hydrualic, or Roller cam?
Old 07-04-2007, 01:58 AM
DG88
DG88's Avatar
Default Soild lift, Hydrualic, or Roller cam?
Which one would you go with?
If you could go back which one would u get?
What experiences has anyone had with any of the three?
DG88 is offline
Old 07-04-2007, 02:03 AM
ZachW04Stang
ZachW04Stang's Avatar
Default RE: Soild lift, Hydrualic, or Roller cam?
What are you doing with your car? From 1985-2001 all 5.0 motors were hydraulic roller from the factory. If its your street car thats what you want. Most of the guys on this forum run a hydraulic roller cam, some earlier guys run hydraulic flat tappet cams since there blocks don't accept roller lifters.
A solid cam is more for racing. I have never owned a car with a solid cam but have worked on a couple. There valves require constant adjustment but I found that most don't seem to loosen adjustment as often as they need to be checked.
ZachW04Stang is offline
Old 07-04-2007, 02:25 AM
ih8chevy
ih8chevy's Avatar
yea the solid is a race cam, not good for the streets. The hydraulic roller would be a good way to go. Its what the typical 5.0 block is and thre are thousands of that type of cam to choose from.
ih8chevy is offline
Old 07-04-2007, 03:03 AM
shawnk007
shawnk007's Avatar
hydraulic roller
shawnk007 is offline
Old 07-04-2007, 04:43 AM
DG88
DG88's Avatar
i was thinking going with some shaft mount Jessels rockers to go with a solid lift cam. I want to make my car a weekend ride only not my daily driver.
DG88 is offline
Old 07-04-2007, 04:49 AM
DG88
DG88's Avatar
Its a 88 GT that i want to make a weekend only ride. Im thinking of going solid lift because they make much more power than the other two and they dorequire to have the rockers adjusted more often but shaft mount will reduce that some. What can you tell me that would have me go hydraulic instead.
DG88 is offline
Old 07-04-2007, 04:53 AM
w8less
w8less's Avatar
ORIGINAL: DG88
dude pass some of that money this way!!!
what kind of rpms are you going to be turning? what that set up can could definitely get up there
w8less is offline
Old 07-04-2007, 04:57 AM
DG88
DG88's Avatar
just want to get to 11s
Are you here in Jasper Tx
DG88 is offline
Old 07-04-2007, 05:22 AM
w8less
w8less's Avatar
no sir i'm in KY.
what kind of motor are you building. you could probably go with the probe shaft mounts as they are cheaper.
you could put the extra money else where.
11s are easy to hit with the proper set up
w8less is offline
Old 07-04-2007, 05:25 AM
FullAuto
FullAuto's Avatar
11s? Geez... That's just a H/C/I combo on a stock shortblock. You can run 11s for just a little over the cost of those Jesels.
FullAuto is offline
Quick Reply: Soild lift, Hydrualic, or Roller cam?
