audio clip of h pipe, does it sound right???
Old 07-04-2007, 01:32 PM
telsonman
telsonman's Avatar
Default audio clip of h pipe, does it sound right???
here is a clip of my o/r h with flow 40s.
http://www.youtube.com/watch?v=PejgEvVsV7U
that popping has occurred since i put the 40 series on, it only usually does it when its cold for some reason. my buddy with an f150 says his does it to, so i'm not sure. anyway, i got an interior part too.
you can't hear the popping in this. it only does it when i'm driving for some reason, and its only when the rpms are from 1200-1800, after that it stops. i only have one of the o2 sensors in, because i can't get the other one out of the stock h-pipe. do you think having that open o2 hole, that it could be making the popping sound i here???
telsonman is offline
Old 07-04-2007, 01:36 PM
mattdel
mattdel's Avatar
Default RE: audio clip of h pipe, does it sound right???
not having the o2 in there will cause more than an exhaust leak. that entire side of the motor is now running richer to compensate for no readings.
mattdel is offline
Old 07-04-2007, 01:38 PM
adumb
adumb's Avatar
it is always hard to diagnose things when you already know you have a major problem... definately fix the o2 sensor and then if it still does it you have a problem
adumb is offline
Old 07-04-2007, 01:39 PM
PJB
PJB's Avatar
Did you try getting the sensor off with an O2 sensor socket (its got a slit in it for the wiring)?
Its not a good idea to drive around without an O2 sensor even if thats not causing the popping.
PJB is offline
Old 07-04-2007, 01:41 PM
93 LX FiveO
93 LX FiveO's Avatar
why would u bolt it up and run it knowing u had no 02 sensor on that side?
and no its not running or sounding right....
93 LX FiveO is offline
89 fox
89 fox's Avatar
ORIGINAL: telsonman
not to be a smartass...but drill a hole in your neck and see if you could breathe right...just go buy a new O2 sensor...2 new ones if ya can and it will help...
89 fox is offline
Old 07-04-2007, 10:40 PM
telsonman
telsonman's Avatar
ok, so i put the o2 sensor back on and its running 40x better now, and it sounds a lot better too. all of the noise went away. i'll try to get another audio clip up later.
for those wondering, i didn't have an o2 sensor on that side because i could get the old one off the stock pipe. but today i got the right wrench and got it off. its only been like 2 days
Old 07-04-2007, 11:58 PM
5pointslow91
5pointslow91's Avatar
i had a hard time taking 1 of mine off the old exhaust, took a big fukn wrench and stood on the pipe n got it took break loose
5pointslow91 is offline
Old 07-05-2007, 12:11 AM
88GT_5.0Stangman
88GT_5.0Stangman's Avatar
I just used a torch and heated it up a bit, and it came out no prob. i hope u anti-seized the new o2's makes it eaiser if you ever have to remove them again
88GT_5.0Stangman is offline
2007CalSpec
12-13-2020 11:42 AM
AmericanMuscle4.6GT
11-10-2015 02:06 PM
wawagner82
09-13-2015 09:02 AM
09-10-2015 08:39 PM
Emblazoned
09-03-2015 10:45 PM
Quick Reply: audio clip of h pipe, does it sound right???
