rear control arms
RE: rear control arms
ehh, ever since i changed my lowers i have a clunk too.....i was thinking it was probably be the u-joint, but i guess i should check, maybe i should get some uppers too.... i was holding off to switch to a 3 link, but that might be a while, damn MM is expensive.
Matt, I have to do some digging around. I know I have an article bookmarked for the pinion angle. If I can't find it, there are a couple shops local to me that has the info. I already have a pinion angle gauge.
I went with the UPR Upper and lowers....and I also got the Axle bushings and bolt kit from them as well...
Great Products...Great Price. They have adjustables too....but they cost a little more $$
The stock bolts have a bigger head base. Same size wrench, but they are made to use with no washers self locking I think. The bolt kit are the kind you would buy at the store that uses flat and locking washers. I would say use the stockers.
Dragonus18
09-09-2015 01:21 AM
09-08-2015 11:50 AM
M3hunter
09-05-2015 03:42 PM
09-01-2015 08:16 PM
