Speed density vaccuum connection
Old 07-06-2007, 05:22 PM
02WhiteGTVert
02WhiteGTVert's Avatar
Default Speed density vaccuum connection
Ok the SD on the '87 wasn't even hooked up,i ran a vaccuum line from the front of the intake to the spacer between the throttle body (has a line on the front and back),then verified that it was getting vaccuum and connected the other side to the SD. is this how it's supposed to be hooked up? i can post apic if i'm not clear about how i hooked it up
02WhiteGTVert is offline
Old 07-06-2007, 11:00 PM
raven_ghostwolf
raven_ghostwolf's Avatar
Default RE: Speed density vaccuum connection
ORIGINAL: 02WhiteGTVert
By spacer are you talking about the EGR spacer between the TB and the inake?
[&:]If you are there should be water lines running from the metal heater core line to the front and a fitting on the passenger rear corner of your intake. that is for water to 'cool' the spacer.
Yes please post a pict.
raven_ghostwolf is offline
Old 07-06-2007, 11:01 PM
AdderMk2
Banned
AdderMk2's Avatar
is your 87 converted to maf?
AdderMk2 is offline
lincolnshibuya
10-06-2015 08:45 AM
Urambo Tauro
10-05-2015 09:37 PM
UrS4
10-03-2015 06:23 AM
breaking
10-02-2015 01:27 PM
BeatnikFink
10-01-2015 08:00 PM
Quick Reply: Speed density vaccuum connection
